7 members (Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 42 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 42 | Well the rear end in my truck is a 5.14 has anyone ever swiched it out or do most people make do wih it i guess i could make do withit well thanks foe the advice Hudson | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | .If this is a 3/4-ton or a 1-ton,Pull your axle shafts,drop your drive-line,pull the removable differential and replace it with a 4:11 diff from a 64 to 72 diff.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Just to clear up what Mechainiac said, you don't remove the entire differential, just the center carrier, commonly called a pumpkin. Tom Meyers in Miami, OK usually has some for sell. Search this forum for his phone number. Jim Carter's website has a tech tip on this swap.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Won't a 3.73 or 3.07 from that same era work? Or is the 5.14 a 14-bolt unit? :confused: | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | This is an Eaton style rear end with a removeable center differential.It unblots from the front of the axle housing and drops out after you pull the axle shafts out and drop the driveline.Remove the ten bolts and it will nearly fall out.You should be able to drain most of the gear oil by removing the lower three bolts first. .I have not found any 3:73 gears yet but I am told they were an option for the big-block pick-ups and suburbans(3/4 ton)
| | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Kook and I did this swap on his 51 GMC 3/4 ton in my garage last summer. He posted the pictures and comments on his web page. www.oldgmctrucks.com Click here for highway speed !
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
