1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#5430 05/08/2002 4:06 AM
Well the rear end in my truck is a 5.14 has anyone ever swiched it out or do most people make do wih it i guess i could make do withit well thanks foe the advice
Hudson
#5431 05/08/2002 4:50 AM
.If this is a 3/4-ton or a 1-ton,Pull your axle shafts,drop your drive-line,pull the removable differential and replace it with a 4:11 diff from a 64 to 72 diff.
#5432 05/08/2002 4:13 PM
Just to clear up what Mechainiac said, you don't remove the entire differential, just the center carrier, commonly called a pumpkin. Tom Meyers in Miami, OK usually has some for sell. Search this forum for his phone number. Jim Carter's website has a tech tip on this swap.
Fred
52 3600
69 C-10
#5433 05/08/2002 4:26 PM
Won't a 3.73 or 3.07 from that same era work? Or is the 5.14 a 14-bolt unit? :confused:
#5434 05/08/2002 4:39 PM
This is an Eaton style rear end with a removeable center differential.It unblots from the front of the axle housing and drops out after you pull the axle shafts out and drop the driveline.Remove the ten bolts and it will nearly fall out.You should be able to drain most of the gear oil by removing the lower three bolts first.
.I have not found any 3:73 gears yet but I am told they were an option for the big-block pick-ups and suburbans(3/4 ton)
#5435 05/08/2002 4:55 PM
Kook and I did this swap on his 51 GMC 3/4 ton in my garage last summer. He posted the pictures and comments on his web page. www.oldgmctrucks.com
Click here for highway speed !
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
