3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#542477 05/31/2009 9:09 PM
Now I know that I've gotta 316 cid blok in my 56 GMC, I try to unlock the id of the hydra-matic.
N 1-4 1-3 1-2 R
GMC Truck Hydra-matic
So can someone give me some tips where I can find the casting codes? The numbers I've found are 8615573, the serialTAG says CA-55-5754.
THNX Already
Oke THNX but my truck should be from 1956, this manual (very interesting by the way)is from 1946-1955. Does that mean that the hydra-matic is 1955? Is that what the TAG CA-55-5775 means?
I was hoping the manuals would "break the code" for you and help with identification. The next advice I would give is to go to www.areds.com snag the 800 phone number and contact Leon.
B&M should also know as it was the early h/matic that actually put them in business
ron
Just out of curiosity, why is it important to know what the casting number means?
You will find much more hydro information over an Old GMC trucks web site.
OldGMCtrucks.com
That's it curiosity, just like the engine numbers and VIN I thought that the numbers of the hydramtic also ment something.
I just want to know if it is the original one that came with the car back in '56. smile
