| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | I have been working to connect the brake/taillights and turn signals on my 1954 Chevy 3100. Everything is working fine except for the fact that when the taillights are on the brake lights will not work. Any ideas? Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | First thing to check is the grounds. Make sure the tail lights housings are grounded & the bed is grounded to the frame. If the wires are crossed the tail lights are real bright & you can't see the turn lights. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I agree w geo Make a concerted effort to make all grounds good on your truck. That way when ever something goes afoul at least you know the grounds are good start there.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do the brake lights work when the tail lights are off?
Also, what type of turn signal set-up do you have? The GM set or a non-original-style set?
| | | | | Joined: Jan 2009 Posts: 22 New Guy | | New Guy Joined: Jan 2009 Posts: 22 | The brake lights do work when the tail lights are off. The tail lights are simply the generic kind you can purchase at Napa as well as the turn signal switch. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | OK, so you do not necessarily have a grounding problem.
What brand of turn-signal mechanism/switch are you using?
How many wires does it have coming out of the switch?
Do you have a set of wiring instructions for signal mechanism/switch?
