8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 52 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 52 | When I was a little younger and didn't know that 6 lug meant 1/2t and 8 lug meant 3/4t I bought a brand new clutch at Auto Zone for 130.00 (clutch/ pressure plate, and throw-out bearing) for a 3/4ton truck and my 49 is actually a 1/2ton/long wheelbase truck. ARE THEY THE SAME CLUTCH!!?? Or do I have a clutch that I can't use now?!!?? My truck is a 4 speed, 248-I6. Thanks
Whether you think you can or can't, you're right.
Also--in 2004, I invented the spotting alert network in stovebolt after seeing so many trucks when driving around. So that means I am cool.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are probably the same. You really can't buy a clutch till you take the old one out. There are a lot of variations & options. Take the old one out & compare them. Then go from there. I know a guy likes to have the parts setting there but clutches are one thing it's best to pull it first. Sometimes the replacement is a newer style then the old one, but if it is the same dia. & you have the complete kit, it will work.
Last edited by Wrenchbender Ret.; 06/01/2009 10:06 PM. Reason: Thought of something else.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
