| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54226 01/01/2006 8:03 AM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I've got access to a rear from a 76 Cutlass, but I want to keep the leafs on my 47 AD. Other than the kit from Chevy Duty, is there a cheaper way to get the necessary hardware?
jay
Your lack of preparation is not my emergency
#54227 01/01/2006 1:43 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Your cutlas rear end is a coil spring and is going to take a lot of clean up work to make it look right. I think I would look for a leaf spring rear with the gears you want, doing this will give spring plates and possibly ubolts. All the other stuff shock mounts drive shaft and so on you can fab up yourself. | | |
#54228 01/01/2006 2:26 PM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Jay, I just finished grinding and removing all brackets from my 84 cutlass rearend and the reason I took the rear is because of the price and the mileage was only 80,000 (less than my '48 has on it)I also purchased my leafspring kit , wich included the shock mount brackets and spring perches to weld on in the right location (center of the wheel well)that tork tube rearends folks have to contend with, brought from:www.truckandcarshop.com funny thing is that the kit came from www.cpp , but i bought it cheeper from tha truck shop! ? go figure. Good luck and make sure u check your pinion angle before you weld. | | |
#54229 01/01/2006 7:37 PM | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Or you can do some measuring and use a camaro or nova rearend like I did on my 57. You still have to move the spring perches on the modern rearend and weld them to the correct area to match the original spring mounting spots. | | |
#54230 01/01/2006 8:24 PM | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Autoazore, When you installed your rearend did you install emergency brake cables for the year rearend you installed or for the year truck? I haven't crossed that bridge yet , but it wont be to far up the road. Thanx | | |
#54231 01/02/2006 6:55 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | At ChevyDuty and CPP the kit costs $140.
I used a similar rear under my '55 1st. I cut the hardware off the original rear and put them on the new rear. If I had it to do again I'd buy one of the kits.
You might find something a little cheaper, but I doubt you'll save much without doing a lot of the work.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#54232 01/03/2006 6:53 PM | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 | I plan on using the rear, even though it will be ugly. My next question is: Which part number shocks will I need for the switch to gas shocks?
