7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible),
90
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54215 01/01/2006 7:12 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Hi, I was kicking around a junkyard and found a 55 or so Chevy Dump Truck with a 235/261 engine. It has a car sitting partially on the hood so I couldn't get it open enough to see the right side of the engine to look at the block casting number or for captain bars. I could get a hand on the head to get a rubbing of the head casting number which is 3836850. I can't find this number on the inliners site or their links. Anyone know what it is for? I realize someone could of switched heads but if it is a 261 head I may go back and push the car off it's hood to have a better look.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#54216 01/01/2006 7:53 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | That is a number for a 261 head. See here.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#54217 01/01/2006 7:59 AM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Hey Grant U Better get ur lollygagin arse back to that bone yard afore I beat ya tooit!!LOL :p 3836850 is whats on my 261 head What the heck just git the whole darn motor man :p Or at least save it for me. BTW Happy new year and regards | | |
#54218 01/01/2006 8:20 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | It's a 261 ci head. I tore one down today. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#54219 01/01/2006 9:27 AM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | Thanks all, I'm after the engine, not really the head. I will go back for the engine if I can get there before stevesr, I just need to find a 4x4 cherry picker?
Happy New Year
#54220 01/01/2006 4:27 PM | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Only teasing But dont let that one slip by! Good luck on getting it, Would be a great way to start the new year off. | | |
#54221 01/02/2006 3:14 AM | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | Gents,
The head on my 261 is cast 3836848 - that looks to be a 235 by the charts - is this possible? How different are the heads from a 235 to a 261?
Another newbie question - if the oil pan on this 261 is punctured - will a 235 or 216 pan fit?
Stewart | | |
#54222 01/02/2006 3:52 AM | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | stewbud, the 848 & 850 heads were installed on 235's & 261's ( respectively ) at the factory. many were swapped over the yrs. & will work on either engine. the 848 head has a smaller combustion chamber resulting in higher compression & better performance. 235's & 261's shared the same oil pan. a 216 oil pan will not fit most 235/261's. the bolt pattern was different & it was equipped with troughs for the spray nozzle jet lube system. i say most because the early 53 powerglide, 54 & 55 1st series truck engines did have the same bolt pattern as the earlier 216's. if all of that trough assembly was knocked out i suppose it would work on those earlier ( 53, 54, 55 1st ) 235 & 261 engines. robert | | |
#54223 01/02/2006 8:02 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Stew, your head is a 235 ci head . 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#54224 01/06/2006 2:58 AM | Joined: Dec 2005 Posts: 26 Apprentice | | Apprentice Joined: Dec 2005 Posts: 26 | Bluechev and bowtietim,
Thanks for the info.
I have been reading some of the old posts and this forum seems to have answers for all of the problems that I see as creeping into my truck restoration.
As a newcomer I appreciate you sharing your expertise in this field.
Stewart | | |
#54225 01/06/2006 4:46 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Location of casting number is actually in front of the fuel pump. The number behind the distributor is the engine serial number. I put a red line locating the number on my 1954 261 ci block. http://img519.imageshack.us/img519/3765/261block6pe.jpg casting number and location on the head of a 1954 261 ci http://img512.imageshack.us/img512/5164/261headpic16qp.jpg location and number on my 848 235 head, i believe it is out of a 1956 car.The last numbers of the casting are 848. http://img512.imageshack.us/img512/7964/848headpic27pa.jpg I thought maybe this would help people understand what casting numbers are and where to find them.I know that i had to ask quite a few questions on this subject,and are still learning. Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
