2 members (Mike Roache, walter74), 110 guests, and 2 robots.
Topics128,049
Posts1,055,740
#542114 05/30/2009 5:06 AM
I just got my '53 1 Ton and cannot get the seat out. I move the bar on the drivers side but it does nothing for me. I have checked the past topics but cannot find anything about seat removal. Hopefully somebody can point me in the right direction.
Huthip
huthip #542135 05/30/2009 7:18 AM
Not sure if it's like my 49 1/2 ton as I haven’t done any research on the one tons but for mine the bottom part of the seat will pop out if you pull it straight up like a folding chair. Then you will have to reach underneath where the seat rail is that allow the seat to side back and fourth. If you feel under there you should feel two nuts you will have to remove. 7/16s if I remember correctly as I just did mine this past weekend. Then on the back of the seat on the floor between the gas tank and where the slide rail there is two more nuts you have to remove. This is on each side. Like I said not really sure if it is setup the same way or not. Good luck and let me know if I was incorrect so I will know incase I run into this again.
Carson Holloway
[email protected]
Truck: 1949 Chevy 3100
Thanks, I will give it a try. Might be a couple of weeks before I get back to it.
Huthip
Moderated by  ndkid275, Phak1
