0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | I just got my '53 1 Ton and cannot get the seat out. I move the bar on the drivers side but it does nothing for me. I have checked the past topics but cannot find anything about seat removal. Hopefully somebody can point me in the right direction.
Huthip | | | | | Joined: May 2009 Posts: 97 Shop Shark | | Shop Shark Joined: May 2009 Posts: 97 | Not sure if it's like my 49 1/2 ton as I haven’t done any research on the one tons but for mine the bottom part of the seat will pop out if you pull it straight up like a folding chair. Then you will have to reach underneath where the seat rail is that allow the seat to side back and fourth. If you feel under there you should feel two nuts you will have to remove. 7/16s if I remember correctly as I just did mine this past weekend. Then on the back of the seat on the floor between the gas tank and where the slide rail there is two more nuts you have to remove. This is on each side. Like I said not really sure if it is setup the same way or not. Good luck and let me know if I was incorrect so I will know incase I run into this again. | | | | | Joined: Feb 2009 Posts: 56 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 56 | Thanks, I will give it a try. Might be a couple of weeks before I get back to it.
Huthip | | |
