6 members (FAST55, dt235sd, TUTS 59, Bill Hanlon, Uncles51, 78buckshot), 63 guests, and 0 robots.
Topics128,043
Posts1,055,614
Junior Member
Junior Member
have a 1948 gmc 1/2 ton . has original 4 speed
trans in it. it is very load! hard to shift!
is there a different 4 speed that would bolt up
to my 228 6 cylender?
Bolting up to your 228 isn't the hard part. The hard part is adapting to your torque tube.
Is something wrong with your 4-speed or is it okay but you have found it difficult to get along with? You might replace it with a better one, or with an original type 3-speed.
Patricks has a kit to adapt a Saginaw car type 4-speed to the torque tube, and that is probably the only non-stock option that does not require replacing the rear with an open type rear.
