| | | Forums66 Topics128,078 Posts1,056,285 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 84 | I'm looking at getting some drop springs for the rear of my 59 L/B fleet. Here is my question. I'm looking at the Brothers catalog and here are my options- Reversed eye mono leaf that drops it 5" for $429.00 and a multi leaf that will drop it 5" for $399.00.....Why would i want a mono leaf and pay an extra $30 if I'm going to get the same drop with multi leaf for the cheaper price? Is there a difference in ride quality with mono compared to the Multi leaf? Also on the task force trucks, how far generally speaking can I drop the rear of the truck before I will have to c-notch the frame? | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | My experience has been that a mono rides a lot stiffer than a multi-leaf. I think I'd go to the 5" multi-leafs in this case.
I don't have a TF truck but if you measure the distance between your bump stop on top of the axle to the bottom of the frame, subtract 5" and that's what you'll have left for spring travel.
Edit: if your bump stop is attached to the frame, measure down to it's contact point, then subtract the 5".
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I was looking into this for my last 57 about 5 years ago. If memory serves, I had something like 6-7 inches of total travel at static ride height. Taking 5 out leaves almost nil for travel. You may get away with it for a cruiser, but don't expect to haul anything. You will bottom out frequently already.
You won't need a C-notch unless you flip the axle on top of the springs, which will net you about a 6" drop, for free. Problem is, you still are left with about an inch of travel. In comes the C-notch. With proper bracing they work fine. There is a posibility you may have to raise your bed floor to clear bracing, depending on how you do it.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
