4 members (Otto Skorzeny, Wayne67vert, fonz8261, 1 invisible), 53 guests, and 4 robots.
Topics128,077
Posts1,056,016
Members48,433
#541945 05/29/2009 6:30 PM
I resurrected a '54 from a field and she is running great. The only problem now is the brakes. I rebuilt the master and all wheel cylinders, replaced all shoes and turned the drums. Everything seemed to work fine for some time. Recently, the brakes seemed really tight. I only needed to push the pedal in less than 1 inch to engage them. It seemed that the rears were dragging. I adjusted them out again but after a little driving they were back in the same tight position. This is a 3/4 ton. Are these brakes self adjusting? How do I keep them from tightening up so much?
Todd
It sounds like you have fluid pressure causing it. The rubber hoses tende to break down over time and they can act as a one way valve.
1951 1 Ton Completed
Riding in the Passing Lane
Make shure you have a little free play in the pedal to the master cyl. If it doesn't come back all the way it will build up pressure. Make sure the emer. brake cables are not adjusted too tight. If they pull the shoes off the anchor pin it will cause drag.
1972 Chevy c10 Cheyenne Super
Come to think of it 1" is a pretty small distance from the top. The master cylinder should be set up so that the pedal backstop is provided by the MC itself.
