0 members (), 118 guests, and 3 robots.
Topics128,196
Posts1,057,393
Members48,471
I would like to get all the info i can get (both pros and cons) on putting a bolt in front suspension out of a 1987 chevy suburban , to a 1954 chevy pick-up.All info will be appreciate it........
L.D
My e-mail address is [email protected]
ubb
Track is too wide. The project is basically the same with '63 - '87 pickup IFS and another year or two Suburban (till the body change).
This swap does give you IFS, and with '72 or later gives disk brakes. Power steering can be part of the deal. It does not lower the truck.
And the track width is too wide.
I've also seen the crossmember itself narrowed. I like the widened fenders approach myself.
Widened fenders seem like a lot of work. How about using the front clip off of a 1 1/2 ton or larger? The fenders are already wider.
Plus they are longer and require a different grill.
