Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (TooMany2count, jmoore, Guitplayer, qdub, JW51), 560 guests, and 2 robots.
Topics126,780
Posts1,039,294
Members48,100
Most Online2,175
Jul 21st, 2025
i was windering if anyone knew if the danan 60 axles from a 2000 excursion close enough in width to fit my 65 k20 that i am abou to start a project on? thanks
Jonathan
Jonathan
_____________
1965 K20 project truck
duramax swap
6speed tranny swap
axle swap
1966 C20 camper special
family heirloom
restoration project
Posted track width (center of tire tread to center of opposite tire tread) for 2000 Excursion
http://www.motortrend.com/cars/2000/ford/excursion/specifications/index.html
Front 1737 mm (68.4")
Rear 1730 mm (68.1")
If you measure your 65 K20 track widths you should have something to compare to.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
thank you very much for the info, but wouldnt the offset of the rims on the axle have difference in the center of tire tread? would it be better to measure from end to end? or does offset keep the center of the tire tread lined with the center of the disc or lug plate?
Jonathan
Jonathan
_____________
duramax swap
6speed tranny swap
axle swap
family heirloom
restoration project
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.121s Queries: 14 (0.032s) Memory: 0.5963 MB (Peak: 0.6324 MB) Data Comp: Zlib Server Time: 2025-09-22 19:09:13 UTC
Valid HTML 5 and Valid CSS
