BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,780 Posts1,039,295 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | i was windering if anyone knew if the danan 60 axles from a 2000 excursion close enough in width to fit my 65 k20 that i am abou to start a project on? thanks Jonathan
Jonathan _____________ 1965 K20 project truck duramax swap 6speed tranny swap axle swap
1966 C20 camper special family heirloom restoration project
| | | | Joined: Mar 2006 Posts: 319 Shop Shark | Shop Shark Joined: Mar 2006 Posts: 319 | Posted track width (center of tire tread to center of opposite tire tread) for 2000 Excursion http://www.motortrend.com/cars/2000/ford/excursion/specifications/index.htmlFront 1737 mm (68.4") Rear 1730 mm (68.1") If you measure your 65 K20 track widths you should have something to compare to.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | Joined: Mar 2009 Posts: 57 Wrench Fetcher | Wrench Fetcher Joined: Mar 2009 Posts: 57 | thank you very much for the info, but wouldnt the offset of the rims on the axle have difference in the center of tire tread? would it be better to measure from end to end? or does offset keep the center of the tire tread lined with the center of the disc or lug plate? Jonathan
