1 members (baldeagle),
87
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Hey it's Pork-
Now i'm putting my front end plate back on. It has 3 machine screws which need to be torqued at 15-20 ft lbs. How do I know what the actual tourque is on the screws? I just took the biggest screwdriver I have and turned as hard as I could. Should I buy an attachment for my torque wrench that's a flat head or should I just turn as hard as i can and assume it's ok? also should i use loctite..
thanks pork
'59 chevy 235 1/2 ton fleetside bbw
1959 Chevy Fleetside 3100 Series BBW
| | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | If the screwdriver bit for a torquewrench is too expensive, you can put a crescent wrench on the screwdriver and tighten it some more. I've used impact screwdrivers that you hit on the end with a hammer while turning screw to tighten. Then stake the screws in place. Loctite isnt a bad idea either. Make sure your gasket between plate and block is good and sealed with red hi tack or spray haylomar. Good time to tap the front main cap for 3/8" bolts if cap is still accessable. Have to clearance drill front plate and timing cover so bolts will clear, tho.
Use new bolts and loctite on the cam retaining plate too. Check timing gear runout and backlash. Good idea to degree cam to be extra sure everything is in spec.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#5421 01/28/2004 11:31 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I just installed my Front plate on my 261 engine and I did as Chiphead recommended using the largest flat-head screw driver that fit the screws. My screwdriver had a wrench hold near the handle and I used an adjustable wrench to give it a little extra torque. I then staked the screw at the bottom of the slot with a punch.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#5422 01/29/2004 12:32 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | 20 ft-lbs isn't very much!
You could get a 12 inch crescent wrench on the screwdriver and place 20 pounds on the end of the wrench.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Thanks guys...
I took the biggest screwdriver i had and put a crescent wrench on the shaft towards the handle and turned the hell out of it.....i think that should do it!!
pork
