0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#54170 12/30/2005 2:34 AM
Although not a bolt, and not gasoline, what do you think....is it possible for a conventional diaphragm type fuel pump to have a torn diaphragm and not leak into the crankcase..but just the opposite. Do you think it could "suck" air/oil out of the crankcase and put it into the system. :confused: :confused:
Stuart
#54171 12/30/2005 3:17 AM
Only way that I can think of is if the crankcase pressure is higher than the fuel pressure, which is not likely. Check the PCV valve by shaking it lengthwise. If it doesn't rattle, it's stuck and needs cleaned or replaced.
Fred
52 3600
69 C-10
#54172 12/30/2005 3:38 AM
The PVC valve Replace it .You can shake raddle and roll.But the ball in the valve is not perfecty round and will not seal after years of use.So change it for a few bucks.The fuel pump yes,Keep a eye on the oil level,also smell the oil for fuel.keep watch on oil pressure
dan-pa
