2 members (Tstan7, Napco Mark),
75
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | I removed my front axle to replace the kingpins. Know I am not sure concerning the alignment of the axle. The axle has a littel curve. Can anyone confirm the correct alignment? [IMG]http://img268.imageshack.us/img268/2266/axle.th.jpg[/IMG]
'59 Apache '67 Mustang
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Hi, I am also doing a frame off and went outside and checked My axle and there is no curve I have a 52-3100 and a 3/4 ton frame outside and nether one is curved You might have to take Your axle to a shop where they can streaten Your axle, alinment shops ( old ones ) have a jig for doing it , Good luck , Pete | | | | | Joined: Feb 2009 Posts: 35 Apprentice | | Apprentice Joined: Feb 2009 Posts: 35 | was the alinment ok when you took it apart? i have seen most with a cruve in them. | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | It shouldn't make any difference, the tie rod ends will adjust to keep the front wheels inline. The most it will do is shorten the track width just a bit. These axles are really tough, I bet it was made like that, you would pull a spring apart before bending the axle in the center. Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | not sure what you mean by "correct alignmant" - the tie rod should be behind the axle, and any 'curve' is down whereas your drawing appears to show a curve to the front - not likely an axle will be bent up/down [more than usual], but might get bent back in an accident - if it has any bend front to back it can be straightened [cold] [ bottom left here] ..... for front steering alignment, details are in the manualBill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | a "barely noticeable" curve down is normal, and as Joe said, won't affect alignment - if it's more pronounced there's been damage, but it may still be useable, and a machine shop might be able to check and fix it - see the manual pages linked above
Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, it will affact the alignment. It will change the camber angle, which is otherwise non-adjustable on these trucks. If it's just a minor bend, it may still be in spec. Onece it's reinstalled in the truck, take it to an alignment shop (one that does semi-trucks would be best) and get it checkeed out (toe needs set anyway). If it's beyond spec, they should be able to bedn it back to the correct position.
Bill Burmeister | | | | | Joined: Feb 2000 Posts: 5,194 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,194 | Sorry about that, I was going off the first picture with the bend front to back. The up and down bend will change the camber, but there is a lot to play with so it may not be any thing to worry about. Get it checked once you have all the weight back on it. Joe | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Any bend in the front axle that is not suppose to be there is going to change Your trucks safty and handeling get it fixed it is not hard to go to a alignment shop and get it right . Pete | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The curve goes toward the front. Or you can reinstall it with the curve facing to the rear, loop a chain over the axle, and then tow your truck around a bit being sure to jerk it hard a few times checking each time to see if you've straithened it back out.
My bet is that curve is the result of someone towing the truck with a chain over the axle and jerking it a few times. Not a good idea.
I don't know how hard these axles are to find in Europe, but if it were me I'd go shoping for another one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Just take it to a shop it will not cost that much and it would be right they been rebending st . axles for ever and getting it right , Pete | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | If you have a chain and 10 ton porta power I'll bet you could take the "bow" out of the axle. Question is that the only bend? A good "truck alignment shop" can make sure the caster and camber is right, or you can set the tow and let it go. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Your pictyres turned out to be really tiny. Can you make them larger? | | | | | Joined: Sep 2007 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 61 | Hi Truckernix! They should be larger now. Here is another one. Does anybody know the angle? http://img341.imageshack.us/my.php?image=e01.jpg
| | | | | Joined: Aug 2005 Posts: 276 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 276 | I have a 53 axle that has a bend just like yours. Who knows the history of these trucks! Questions still remains, were some of the axles made this way or the were the bends the result of trauma such as OldSub's theory of chain towing. | | |
