3 members (RLB, Mr Crosswrench, 1 invisible), 109 guests, and 1 robot.
Topics128,132
Posts1,056,391
Members48,441
#540907 05/26/2009 3:39 AM
Apprentice
Apprentice
Hello....My friend just bought either a 1956 0r 57 chevy 3100 truck and need to find out what year it is. I see the blue tag on the driver side door jam and lists a trim number and paint code but no VIN number. Where is the VIN number located on these trucks? Please don't tell me it's on the frame as it sits on a 1977 truck chassis. I did see on the lower left corner of the tage is printed 56 and is not stamped like the other numbers. Any help would be great. Thanks!!
there should be a small metal tag on the drivers door pillar above the dogleg with just the word CHEVROLET and below it a number - a 56 3100 would start 3A56XXXXXX and a 57 would be 3A57XXXX [or V3A if it was originally a V8 truck] .... the primary visual difference is the 55/6 hood is flat topped, the 57 has 2 'wind splits' sticking up - aside from the pronounced grill difference and different fender spears there's really no difference in those years .... and yes, a partial vin maight have been on the top of the frame rail by the steering box
Apprentice
Apprentice
Bill...So, there should be two tags? A small one above the larger rectangular one held in by two rivits? Is that what you are saying?
yes, the smaller is 1"x3.25" [happen to have one laying on the desk grin ] it's unpainted stainless and held to the pillar with 2 small spot welds, you might see evidence of them if the tag is gone - it only has the vin#, the other is the data plate with GVW and such .... without the vin tag there's no way to positively ID the truck - but if it's on a different chassis anyway, call it whatever grill you put in it wink
Apprentice
Apprentice
Thank you....I will look for that tag today. I have a feeling that it has been removed.
Apprentice
Apprentice
Well, my vin tag is gone. Do they reproduce these by chance?
no the tags are not reproduced .... might try a post in the swapmeet, or check with a title company, but might check with the OR motor vehicle folks, most states frown on swaping titles about wink
Ex Hall Monitor
Ex Hall Monitor
Like Bill said, talk with the Oregon licensing authority. They're the folks you'll have to please in the end.
