6 members (Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, klhansen, 1 invisible), 54 guests, and 2 robots.
Topics128,059
Posts1,055,820
#54122 12/29/2005 2:08 AM
I have a broken rear shackle on my 4t6 3/4 ton.
How is the eye bolt removed? Do you just drive it out from inside the frame or is there a special trick/tool needed? Thanks prior
http://community.webshots.com/mypho...mp;photoID=512695738&security=mzbJPM
Dan
#54123 12/30/2005 3:26 AM
The shop manual tells how to do it. If you don't have one, go to http://chevy.tocmp.com
Fred
52 3600
69 C-10
#54124 12/30/2005 3:33 AM
Dan,
I am not sure which bolt you are talking about.. I can't access your webshot...But...I just took my springs/rear off the truck. To remove the rear shackles, remove the bolt that holds the shackle together. Knock the shackles off. The bolts that go through the frame and spring are threaded. They will screw out if you keep the shackle on one end or the other..
What worked for me...
If you have not done so, I would recommend replacing the bushings while you are this far torn down. Mine were worn all the way to the frame eye and the bolts were worn half through. On one side, I was able to leave the bolt in the frame bushing and drive it out with a large hammer. On the other side, the threads were worn away and the shackle bolt just flopped around in the hold The bushing would not budge..I had to saw, chisel etc the bushing until I collapse it enough to drive it out.
While you are at it, check your front bolts. Again, mine were half gone and my truck seemed to be well maintained....
If you are talking about the non-shackle end of the spring, nut on one side, threaded bolt. Impact wrench took it out nicely.
Is this what you were looking for?
