8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible), 159 guests, and 1 robot.
Topics128,081
Posts1,055,955
Members48,430
#540293 05/23/2009 5:43 PM
Seems a frequently asked question is "how get better gears so I can cruise at current hiway speeds?".
I bought this Chevy motor home rear axle 11,000 lb axle a few years ago to put under my '38 1-1/2 ton.
Axle ratings for 1-1/2 ton trucks up through '54 are also 11,000 lbs and the width is identical to my '38. The bolt pattern accepts '54 big truck wheels or later model 19.5's.
The motor home axle is a Dana 80 with parts and a wide range of gear ratios readily available.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #540324 05/23/2009 9:07 PM
Thanks for sharing, that's a great idea!
The Dana 80 axles can be had with gears as fast as 3.31. Or if you find a 70HD they can be had with 3.54. Either way you'll need to swap gears if you want the really fast ones, as most RV's and box trucks had 4.something or slower.
Read more about axle swaps in this tech tip:
http://www.stovebolt.com/techtips/bigbolts/p30swap/
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #540434 05/24/2009 6:26 AM
I never thought of that. I go to truck salvage auctions and motor home axles are almost worthless because motor home owners don't think of salvage parts as an option.
For those of you with COE trucks that are looking for new frames and drivelines, pick up an older motorhome and use it. Take off the body (and put it in the backyard as your new home once momma finds out what you bought!) and you have an new foundation for your truck with a newer engine, transmission, axles and brakes.
Some of the newer motorhomes have disk brakes on both front and rear axles. You should also have better luck hooking up these upright steering boxes!
Lane
