8 members (klhansen, Shade Baby, Shaffer's1950, JW51, Cosmo, Oswald, 2 invisible), 57 guests, and 4 robots.
Topics128,075
Posts1,055,919
Members48,429
#540352 05/24/2009 12:03 AM
I trying to identify the rear end in my 52 3/4 ton. I was very close to being able to drive it around the yard and went to bleed the brakes and the bleed screw snapped off (at least it made me think of spraying the other side with PB-Blaster). Since the truck had been sitting for 10 years I decided I might as well change out the wheel cylinder. The problem with that is I don't know what this rear came from. Previous owner said the guy before him put a nova rear in. He had so many trucks I can't trust his word.
Its a GM 12 bolt, number cast into the housing on the front passenger side is NF3896838. Cast number on the other side is GM 60. Stamped on the front top of the passenger side axle tube is THB W166 1 E. I did a search in google for the cast number, a few things came up, a few chevy trucks in the 60's to 70's range.
Some pictures to help
http://i175.photobucket.com/albums/w124/rockfan1815/rear%20axle/PIC00012.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/rear%20axle/PIC00011.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/rear%20axle/100_0980.jpg
Thank you for any help you can offer
How many lugs? If it has six lugs I'd say a 60's 1/2-ton truck...
OldSub #540429 05/24/2009 6:18 AM
I believe the THB W 166 1 E sequence decodes as
THB = 1971 1/2 ton 3.07:1 ratio (3.73 was standard, 3.07 optional)
W = Warren, Mich (plant)
166 = June 15 (166th day of year)
1 = Dayshift
E = Eaton positraction differential
Found the THB reference here:
http://www.americanclassic.com/paint.htm?p1=axles
Used the site sequence example for 71 and later axles to decode the rest:
http://novaresource.org/axle.htm
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
randyl #540527 05/24/2009 6:53 PM
Thanks guys
ordered my wheel cylinders
