4 members (Chip O, Hotrod Lincoln, TooMany2count, 1 invisible), 88 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#540456 05/24/2009 1:11 PM
I'm rebuilding my speedo on a 53 5 window my problem is the needle will not stay in place. Does anybody know how the needle is held inplace? Does it snap in or something.
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #540473 05/24/2009 3:01 PM
Originally just a light press fit.
Will some super glue work for you?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #540488 05/24/2009 4:04 PM
Thanks Grigg,
don't know if supereglue will work or not but I'm not tlaking about attaching the new needle to the old cover. My problem is getting the base to stay in the actual housing itself, the small needle doesn't seemed to latch to anything.
1953 5 Window
2006 Chevy Colarado
Charley #540501 05/24/2009 4:51 PM
The "hub" that the needle is permanently attached to should be the light press fit on the itty bitty shaft.
Grigg
