1 members (Materman),
107
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | After mounting up some spiffy new brake lights on my Grumman, I carefully noted that they did in fact work.
Some weeks later, they stopped. The turn signal switch arm felt a little funny, so I went ahead and pulled the steering wheel and dug down to it.
What I found was a dislodged spring/contactor. I bent it to look like its opposite. Things are working now, but I still get an intermittent failure that some jiggling resets.
The spring/contactors {viewed as a pair in the mount} have a heart shape to them, and a plastic tab from the signal arm sits between them to move the spring/contactor and close the circuit.
Any idea where I could find some spring/contactors? Being a Grumman {where they seemed to use whatever was available}, I am not sure of what year Chevy the turn signal switch is from, any help there? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The chassis is Chev. & the parts correspond to the year model. They are listed as P series instead of C or K. I.E. P-10, P-20, or P-30. But usually are the same. They did keep the old straight axle on the P series till 1967. I have had that problem with those contacts also. The specialty suppliers might have them but I dought it. You usually can fix them with some needle nose pliers & patients. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | exact copy of my "63" speedo!
http://i.ebayimg.com/11/!BS1d()wBWk~$(KGrHgoH-CQEjlLl1C88BKFMbtoeRg~~_1.JPG | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that gauge assembly is 55-59 Chev, no doubt used other years in utility vehicle, but it may mean the turn sig assy is 5-9 as well .... like this, or look at 60's stuff in vendors catalogs Bill | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Thanks for the pix Red, but no match. Any suggestions for a vendor with an online catalog? | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | There is a NOS set up for sale on Ebay, maybe lookin' will give you some info. Item #350201685825. Good luck.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | doesnt look anything like mine.
If I could find an online catalog with decent pix, I might be able to figure out what vehicle my switch came from. The steering column was for an automatic even though I have a manual trans. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The switch you describe was used in 66 on back to about 63. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Thanks WBender, just spotted one spec'd for an Impala, now I can begin the hunt! Best price seen so far, $60 + shipping.
Dang, all I want is a few of those spring/contact thingies! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Post an ad in the Parts Wanted section. Some of the fellow Stovebolters might have one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
