1 members (Bill Hanlon),
48
Mod | | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | I'm rebuilding my speedo on a 53 5 window my problem is the needle will not stay in place. Does anybody know how the needle is held inplace? Does it snap in or something.
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Originally just a light press fit. Will some super glue work for you?
Grigg | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Thanks Grigg,
don't know if supereglue will work or not but I'm not tlaking about attaching the new needle to the old cover. My problem is getting the base to stay in the actual housing itself, the small needle doesn't seemed to latch to anything.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The "hub" that the needle is permanently attached to should be the light press fit on the itty bitty shaft.
Grigg | | |
