| | | Forums66 Topics128,124 Posts1,056,334 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 15 New Guy | | New Guy Joined: May 2009 Posts: 15 | which is better or easier to install on a 1955 2nd series. And maybe some tip, tricks, and pics.
| | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | The easy answer is, it depends... :-) The Toyota box (if you can find one) has a side-output like the original, mounts in the same (or close) location and will run the stock steering with few mods. From what I understand, they stand up well to off-road use, and should be reliable. It may require a new pitman arm and a modified drag link due to spline count, mounting height, etc.
The chevy box is a bottom-output designed for cross-link steering (uses two tie rods and a center rod, sorta like R+P, and uses the box at one end of the center rod and an idler arm at the other to hold it all to the truck). As a result, they are designed to mount forward on the frame rail (have to move the left shock mount) and require a different pitman arm, drag link and steering arm to run the steering.
Kits are available for both, including boxes for both. I see them in ads in the mags for about $699.
Good luck with your decision.
... I wonder if anyone has tried flipping the steering arms on a straight-axle truck and using a full cross-link installation?....
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | |
