8 members (Deegs53, Gdads51, Wheelie, TUTS 59, stlcardinalsguy, Maybellene, Wally / Montana, Otto Skorzeny),
256
Mod | | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53974 12/26/2005 1:08 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | First of all, Merry Christmas!. Second, I am trying to figure out what the gear ratio of my 60 GMC is. I jacked up that back end, marked the driveshaft, marked the wheel. Here is where I am confused, for every full rotation of the wheel, the driveshaft rotates twice. I thought the driveshaft should rotate close to four times for a 3.90 or 4.10 ratio. Am I doing something wrong? Another thing, if only one wheel rotates at a time, do I have limited slip? I thought that if one rotates one way, and the other wheel goes the other way, that means you don't have limited slip. Is that true? Thanks! | | |
#53975 12/26/2005 1:21 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Merry Christmas, firstly if only one wheel turns it's not a limited slip [very rare option in those days]. Secondly you are overlooking the differetial gears themselves, those are the gears that allow the two axles to turn at different speeds when you go around a corner. If when doing your test only one wheel turned, you can basically double your driveshafts number of turns giving you a ratio of 4 to 1, hope this helps. | | |
#53976 12/26/2005 2:30 AM | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks! The reason I thought it was limited slip was that behind the seat on the cardboard covering, the is a sticker that say something about "this vehicle is eqquiped with a limited slip differential...."..a cation sticker. So basically I have a 3.90 or 4.10 gear set then? Your explination makes sense. Thanks! | | |
