2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53971 12/25/2005 7:17 PM | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | I have a 51 1/2 ton Chevy with a 54 Chevy engine. The carb needs to be rebuilt but I am having trouble IDing the carb. A number of the catalogs have kits but I really don't know which one to order. Anyone know what carb. came with the 54 235? Also, I have limited engine experience but can do the basic tune-up stuff....so is this a job I should try to tackle myself? Thanks - KenZ | | |
#53972 12/25/2005 7:54 PM | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | Rebuilding carburaters is a fairly easy job if you take your time and have a good clean work surface. You will need carb cleaner and pipe cleaners, some small wire and a brush. Use the wire and pipe cleaners along with solvent to clean in the holes and tubes. Compressed air helps! You really have to get the inside as clean as possible. The solvent that comes with a basket for soaking is better, since it can soak over night. But spray cans work pretty good, just use a lot of it and be thorough. The mechanics of the carburater is pretty simple, the few moving parts are easy to understand and all the kits have good instructions. Most shop manuals have the same information. Most one barrels are the same other then the jetting and metering rods. The main thing now is to find the ID tag on your carburater. You must have the correct model number before ordering the kit. The kits cover a lot of different models, but you still need to be in the right area. Just because it was on the engine, doesnt mean its the original carb! You could try posting a picture of it if you can't find the tag. Joe | | |
#53973 12/26/2005 1:56 AM | Joined: Dec 2005 Posts: 48 Member | | Member Joined: Dec 2005 Posts: 48 | Joe - Thanks for your pointers. I'm ready to have at it and I figured the next step was to properly ID the actual carb that's on it. Shot, with my limited experience, it was only recently that I figured out I had a 54 engine in my 51 truck. It came that way, what can I tell ya. Should be fun! KenZ | | |
