1 members (dunfire),
157
Mod | | | Forums66 Topics128,162 Posts1,056,941 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53959 12/25/2005 3:13 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | my 1940 chevrolet service manual says the Special DeLuxe and Master DeLuxe came with 4:11 rear axel ratio , the Master 85 came with 3:73 rear axel ratio. Houseing is stamped with B + number for 4:11 or C + number for 3:73. I want to swap the 4:11 ring and pinion from my 1940 suburban 1/2 ton and use the 3:73 Master 85 car ring and pinion . Any done this? Does the closed drive shaft drop down from rear of transmisson so the rear end assy can be unbolted and removed without un hooking bango houseing brake lines ect.ect. | | |
#53960 12/25/2005 3:32 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd suggest you find out if the car and truck rear ends are actually the same, and can have parts interchanged - that isn't the case on things later on, and I suspect you find they're different
but yes, the torque tube comes free of the trans and the entire rear and tube can come out as a unit
Bill | | |
#53961 12/25/2005 3:54 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | red58 I'm not sure if the suburban is considered a stationwagon/car or truck? Glad to know I can remove drive shaft and ring and pinion with out removeing houseing. thanks Bill | | |
#53962 12/25/2005 4:15 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the burb is a truck based vehicle, the Master series cars are a lighter, somewhat smaller chassis w/ softer suspension, and by 40 I think A-arm front end
Bill | | |
#53963 12/25/2005 4:50 AM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | the suburban has leaf springs and knee action shocks front and rear.  | | |
#53964 12/25/2005 5:52 PM | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I don't think the ring and pinion can be swapped from car to 1/2 ton. I read some information awhile back on the Inliners site that addressed this particular swap. A search there may give you exactly the information you need. | | |
#53965 12/25/2005 5:54 PM | Joined: Jan 2004 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 103 | Got in touch with Barry Weeks so I now know car ring & pinnions are smaller than truck and will not fit. thanks for your help looks like patricks 3:55 set or a complete rearend swap. :mad: | | |
#53966 12/25/2005 6:01 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | None of the rear end parts between passenger and truck will interchange, NONE! However I swapped the entire passenger rear end 3:55 unit into my 46 half ton, look in tech tips(torque tube swap). I eventually removed this rear end for an open drive as I wanted to modernize the trany, but it worked just great for many years. | | |
#53967 12/25/2005 8:07 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Thanks Jim, when I emailed Bill last night about the ring and pinions, I had mentioned swapping the whole Powerglide rear end in, but I didn't know the details as I have never done that swap myself. All the details are in your Tech Tip (under transmissions). DUH!! I should know by now to look in Tech Tips first, many questions are answered there! I always forget. I think 6cylindersovertexas uses the Powerglide rearend in his '37 also. I'm assuming you have to lengthen or shorten the torque tube and driveshaft? And the u-joint should fit right on, doesn't it? | | |
#53968 12/25/2005 9:01 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | In my 46 pickup I didn't have to change the length of the torque tube although the prop shaft/splines at the U joint could have been an inch longer, but worked ok. For the 40 and earlier you'll just have to try it and see, may be just right. Also this swap is made very easy in that the spines of the car and truck torque tube to U jt. are the same. As I wanted to stay 6 lug, so I stuck the 3:55 ratio 54 torque tube in a 48 passenger axle, which btw uses same brake parts as pickup.
Only other mods were to move the spring perch over to fit the springs, lowering block to get back to stock ride height and center the axle in the wheel opening. | | |
#53969 12/25/2005 10:25 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Yup, a '39-'40 has a 1-1/2" shorter wheelbase than a '41-'46, so the driveshaft length might be just right. On Joe's '37 the wheelbase is 1-1/2" shorter yet, so I wonder if he had to shorten the driveshaft then? I know he told me at one time, but I forget. You got your ears on out there Joe? Can you add to this? | | |
#53970 12/26/2005 12:57 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yo - Barry! Everything I know about doing this swap, you guys have covered. I did this swap on my 37 in about 1985. It has been fantastic since then. I did have to shorten the tube and propeller shaft (drive shaft). Everything hooks up fine. The number of splines on a truck up to 1941 are 10, but then went to 17. The Power Glide has 17 splines so below 1941 you have to "mix and match" to get the splines to work out. I am going to be pulling my Power Glide rear end soon and going to an open drive line. When I pull it, I plan on listing it in the Swap Meet. It will fit 34-38 1/2 ton pick up trucks. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
