0 members (), 134 guests, and 4 robots.
Topics128,193
Posts1,057,258
Members48,466
Who do you recommend for patch panels (price, quality and service)I need the usu ohwellal for "FRED" the 65 sslwb
i have used lmc- they are pretty cheap, a little thinner than stock. i use theirrockers and cab supports. i have used ohers over the internet seemed about the same. if you can get a panel from a real truck you would be better off, but this is hard with some stuff. good luck. hr
Thank you for your response. At least someone reads this stuff.
if you have a NAPA nearby, might check them to see if they list the pieces you need
