5 members (Gdads51, TUTS 59, 55shaker, MikeStone1953, Wally / Montana), 138 guests, and 1 robot.
Topics128,109
Posts1,056,258
Members48,437
#539039 05/19/2009 1:56 AM
Does anyone know where to get bushings for a panel/suburban front sway bar
1/2 ton '41-'50?
I also need the caps that hold the bar onto the mounts.
Thank you,
Ray
Thanks tclederman,
I looked on that sight but only found the aftermarket kit.
Cheers,
Ray
0
0 Offline
You can find them at Jim Carter Truck Parts. Type www.oldchevytrucks.biz/47_55/full.asp?page=109
If that doesn't work, just do a yahoo or google search for Jim Carter Truck Parts and he has several catalogs to choose from for the different years of parts that he sells. Search in the47-55 catalog on page 109. GOOD PEOPLE!!
Later, Herb
Now I just need to find the caps that hold the bar onto the mounts, they are semi circular with a bolt hole at each end, anybody out there have a set?
Ask in the Swap Meet
There are sellers of parts that do not come into the discussion fora - they only visit/search/peruse the swap meet.
Thanks, I just bumped my post in the parts wanted.
