| | | Forums66 Topics128,130 Posts1,056,367 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Does anyone know where to get bushings for a panel/suburban front sway bar 1/2 ton '41-'50?
I also need the caps that hold the bar onto the mounts.
Thank you,
Ray | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Thanks tclederman, I looked on that sight but only found the aftermarket kit.
Cheers,
Ray | | | | | Joined: Aug 2008 Posts: 11 New Guy | | New Guy Joined: Aug 2008 Posts: 11 | You can find them at Jim Carter Truck Parts. Type www.oldchevytrucks.biz/47_55/full.asp?page=109If that doesn't work, just do a yahoo or google search for Jim Carter Truck Parts and he has several catalogs to choose from for the different years of parts that he sells. Search in the47-55 catalog on page 109. GOOD PEOPLE!! Later, Herb | | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Now I just need to find the caps that hold the bar onto the mounts, they are semi circular with a bolt hole at each end, anybody out there have a set?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ask in the Swap Meet
There are sellers of parts that do not come into the discussion fora - they only visit/search/peruse the swap meet.
| | | | | Joined: Oct 2005 Posts: 90 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 90 | Thanks, I just bumped my post in the parts wanted. | | |
