| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53872 12/22/2005 10:13 PM | Joined: Oct 2005 Posts: 116 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 116 | I have a '65 Chevy C10 w/ 230 , 3 on the tree . I've been told ( at a tranny repair shop ) that my tranny is the "shorty " model. It is a (non-synchronized 1st gear) 3 speed . The truck has a one-piece driveshaft . Does anyone know the designation for this tranny ?
" The heart of the wise inclines to the right , but the heart of the fool to the left " - Ecclesiastes 10:2
#53873 12/22/2005 11:07 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, standard Chevy 3 speed!  don't know about 'shorty' - in 68 they started using a Saginaw all syncro 3spd that was the same length, fits right in - you have what they used before that for decades, the Muncie or BW, one heavier duty, one standard, but all "corporate" - will have a model number, but better identified by the numbers on it and date codes Bill | | |
#53874 12/23/2005 1:26 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Red58, Is there a link to a page that shows the transmission number codes and how to decipher the date codes? I am trying to determine the year of my non-original SM420, which is in my 54 GMC 100. Thanks.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#53875 12/23/2005 2:20 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | cojo - very minor differences in the SM420 from 47-67 - see about halfway down here Bill | | |
#53876 12/23/2005 6:34 PM | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | i also have a 65 chevy c10 with 230 I-6 and 3 speed on the column (got it for $50 with blown motor has a real nice patina look) i've heard of the non-syncro trannys and was told that you kinda have to double clutch so what do you mean by 1st gear is not syncroed that and like a SM420 4 speed out of a 55 2nd series 3/4 ton be syncroed? Nate | | |
#53877 12/23/2005 7:27 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Thanks Red58! Good site.
The SM420 is not synchroed for 1st and reverse gears, but 2nd-3rd and 3rd-4th are synchroed. You do sometimes need to double clutch even with the SM420 that has synchro rings.
#53878 12/24/2005 6:03 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | From the Novak site I was able to determine that my SM420 4-speed transmission falls in the year range of 64-67 since my transmission # is 3761930.
Here's the Novak tranny ID info:
1947-1953: No ribs on the case, grooved input shaft instead of neoprene seal. Synchro rings all differ from each other. 1st-2nd synchro ring is bronze. Six digit casting number on the case, usually like "59xxxx".
1954-1963: Same as previous but uses a neoprene input oil seal.
1964-1967: Same as previous except 1st-2nd synchro ring is aluminum and 3rd-4th synchro rings are identical to each other. Seven digit casting number usually like "37xxxxx", "38xxxxx" or "39xxxxx".
One thing that puzzles me is that what I believe to be the date code for my transmission reads "J288" which I would think would decode to October 28, 1968. The Novak site states that the last year the SM420 was built was 1967, so is this statement incorrect or is my interpretation of the date code incorrect?
#53879 12/24/2005 6:39 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | your date decode souds right - actually that "last year" would be the last year used as standard equipment - could be later manufacture and is a replacement?
Bill | | |
