6 members (TGP, Bill Hanlon, Hotrod Lincoln, greenie-reddy, 1955 1 Series, Otto Skorzeny), 178 guests, and 3 robots.
Topics128,108
Posts1,056,228
Members48,436
#538446 05/17/2009 2:26 AM
What other size engine manifolds will fit the 228 GMC? A previous owner attempted to weld them together under the carb area and when I pulled it off to change the gaskets, the weld broke and took some of the manifold as well.
39to53 228,248 is the same intake manifold. It has the small ports and the larger manifolds will not match the alignment rings. 228 from 39 to 54 are the same. Larger manifolds will fit. The outlet will be larger on the larger engine manifold, but that shouldn't present too much of a problem.
I'll agree with everything above, but I will also add the 55 248 and the 56-59 270s as these were also small port engines.
Is there any chevy 6 manifolds that will work??
(Thanks for the info so far)
Russell
Why would a chevy manifold fit the longer gmc motor? (Look up long motor envy) Chevy manifolds fit chevy engines, gmc manifolds fit gmc engines of this vintage. You might be able to make a chevy manifold fit with a "BFH".
ummmm...good answer there buddy...I'm a little new to these older inline sixes, but I do know that later on gmc trucks used chevy engines.
