| | | Forums66 Topics128,037 Posts1,055,470 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 86 | My 59 Viking 60 has/had (only pieces are still there) a sticker stuck to the top of the dash on how to shift the 2 speed. Does anyone know where to get a replacement/ repro sticker?
Matt
"Brunhilde II" '59 Viking 60 To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
| | | | | Joined: Apr 2009 Posts: 23 New Guy | | New Guy Joined: Apr 2009 Posts: 23 | Jim Carter has 2 speed shift decals for 47 to 55. Not sure if it's the same as 59, hope this helps. Steven T
Believe none of what you hear and only part of what you see
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2004 Posts: 86 'Bolter | | 'Bolter Joined: Aug 2004 Posts: 86 | Even if it looked like that, it wouldn't look like that. What's left of it is different because I have the knob on the shift lever. I will check Jim Carter, however.
Thanks guys.
Matt
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Jim Carter decal is the same. | | | | | Joined: Jun 2009 Posts: 12 New Guy | | New Guy Joined: Jun 2009 Posts: 12 | | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Thanks for the picture! Mike B  | | |
