8 members (tclederman, Hambone, sron48, Gdads51, cmayna, dt235sd, papas52, Bruce 1954-4100), 140 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
My 39 Chevy 1/2 ton needs the trans rebuilt. Where can a find a rebuild kit for 3 speed? Or it is just best to try to find another trans in better shape?
There is no rebuild kit for Your trans it depends on what parts it needs if it just needs bearings and or seals or bushings You could match them up at a bearing shop if You need gears than You could get another trans and mix parts on both to make one good one, get a shop manual , they are not that hard to fix just take Your time and have fun , Pete
Riding in the Passing Lane
They are pretty easy to rebuild. I dont think there is a full rebuild kit avaiable but all the bearings & seals & gaskets are available from a parts store & the specialty suppliers have the other parts.
1972 Chevy c10 Cheyenne Super
You Tube
I think I'm going to try to do the rebuild myself. What's the worst that can happen? If I mess it up I'm no farther behind then I am now. Thanks for the parts list. I'll order them Monday.
Scott
I have a 54 3600 truck with an open driveline. Would the seal kit on the Chev's of the 40 site work for my application or do I need to keep looking?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
