2 members (JW51, 78buckshot),
86
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | My 39 Chevy 1/2 ton needs the trans rebuilt. Where can a find a rebuild kit for 3 speed? Or it is just best to try to find another trans in better shape? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | There is no rebuild kit for Your trans it depends on what parts it needs if it just needs bearings and or seals or bushings You could match them up at a bearing shop if You need gears than You could get another trans and mix parts on both to make one good one, get a shop manual , they are not that hard to fix just take Your time and have fun , Pete | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are pretty easy to rebuild. I dont think there is a full rebuild kit avaiable but all the bearings & seals & gaskets are available from a parts store & the specialty suppliers have the other parts. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 |
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I think I'm going to try to do the rebuild myself. What's the worst that can happen? If I mess it up I'm no farther behind then I am now. Thanks for the parts list. I'll order them Monday.
Scott | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I have a 54 3600 truck with an open driveline. Would the seal kit on the Chev's of the 40 site work for my application or do I need to keep looking? | | |
