0 members (),
284
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Anybody know off the top of their heads if the rear ends are the same for all 1 tons? I realize the duallies will have longer studs but is there any other differance?
Bruce | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Can I narrow the scope of your question? Looking just at the years with Eaton rears?
The Eaton rear was under all '47 and later 1-ton GM trucks up into the 60's, but by the end of the 60's Dana rears were used under at least some 3/4-ton trucks and may also have appeared under some 1-tons. Sometime in the 70's the GM 14-bolt replaced the Eaton, and though they have some similarities, they are a different rear. And at some point many 1-ton trucks came with the Dana 70HD including my own '89 K3500.
So I'm going to assume your question was just about GM trucks with the Eaton rear.
The spring pads welded on a '61 1-ton Eaton are wider and possibly positioned differently than on a '55 1st 1-ton Eaton. I've seen this difference with my own eyes and based upon it would imagine that the spring pads may be a little different in each series of trucks.
Another area of difference is the brakes. Early rears have Huck brakes and later ones have Bendix. I've heard enough about the problems in switching that I'd suggest getting a rear with the brakes you want. Aparently both the housing and the axle shafts are different between these two types of brakes.
I doubt this is an exhaustive list of all the differences, but just the items I could list mean the quick answer is no, they are not all the same.
If you can be more specific it may be that I'm listing differences that don't matter to you.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Wow, thanks for the information. I've saved that for future reference. I guess my question was vague to everybody but me. I have two '54 1 tons, what I was wondering is; is a 1 ton single tire rear end the same as a dual tire rear end with the exception of the studs?
Bruce | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Bruce I just don't know the answer with certainty. I think the answer is that they are the same, but I can't prove it. The information listed in the Restoration Pack does not show any differences in either the rear axle or the brakes on the rear, and even shows the same wheel bearings front and rear on all 1-tons. The front wheel bearings are the same on 3/4-ton to 1.5-ton trucks according to the resto pack. Restoration Pack
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | Bruce,
Have you measured the wheel mounting surfaces face to face?
Usually, the dually rears are slightly wider in order to get the inside tire away from the spring because of the wheel offset. Spacing of the spring mounts 'should' be the same depending upon frame width (usually around 34 inches for a one ton).
Lane | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Here's what I've found. The 3/4 and 1 tons use the same axles so I would assume the same case. The only differance for the dual wheel option I can find is the length of the studs.
Bruce | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | Lane,the spring mounts on AD and TF ton rears are the same,the AD had a 36 inch frame and TF had a 34 inch frame.The difference was in the spring hangers.I'm using a 55 TF 3/4 rear under my 50,better gear and brakes are a lot easier to find.Also my 16 inch duals fit over the drums.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think if you go to the online parts manual on "Old Chevy Manuals" you will find that the drums are different part numbers between the single and the dual. At least that is the case for 1951.
