2 members (Hotrod Lincoln, greenie-reddy), 96 guests, and 2 robots.
Topics128,049
Posts1,055,741
#532323 04/26/2009 3:00 PM
I'm going to plumb a line from the intake manifold on my 235 to handle the 2-speed rear and the future power brake booster(hydrovac?) What size line do I need? The vacuum wipers will be handled by the fuel/vacuum pump. I will run a flexible line between the engine and the cab.
Riding in the Passing Lane
It's been a long time but it seems like they used 1/2 hose for that.
1972 Chevy c10 Cheyenne Super
I own a '54 4100 and I wanted to know where can you get that 1/2" steel vacuum line that goes from the intake manifold to the hydravac and 2-speed rear end. I can only find 3/8" or smaller line. Thanks in advance.
Plastic or "Synflex" air brake hose would probably work. I is available at any truck parts house that carries stuff for air brakes.
stoveboltkid,
i duno if this helps but i made my own. if you go to any parts store and find the right fittings to screw into the intake and hydravac you can simply slide 3/8 fuel line on it clamp it and off ya go
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
Also I've seen check valves on each line after it exits the intake manifold. What kind do i need?
those are on newer model trucks arent they ? like the ones on the brake booster? if it is i duno the part number off hand but ill get you the # tomarrow
Pictures on Flickr
i also like this idea... with a heat gun you could "mold" the line to take any shape to contour and be out of the way for a custom look, im gonna have to experiment, thanks for the idea crenwelge!!!
Pictures on Flickr
stoveboltkid,
i got the checkvalve part number you were talking about, Advance part number (sku) 80190 Power brake booster check valve
Pictures on Flickr
