| | | Forums66 Topics128,051 Posts1,055,766 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I'm going to plumb a line from the intake manifold on my 235 to handle the 2-speed rear and the future power brake booster(hydrovac?) What size line do I need? The vacuum wipers will be handled by the fuel/vacuum pump. I will run a flexible line between the engine and the cab. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It's been a long time but it seems like they used 1/2 hose for that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I own a '54 4100 and I wanted to know where can you get that 1/2" steel vacuum line that goes from the intake manifold to the hydravac and 2-speed rear end. I can only find 3/8" or smaller line. Thanks in advance.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Plastic or "Synflex" air brake hose would probably work. I is available at any truck parts house that carries stuff for air brakes. | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | stoveboltkid, i duno if this helps but i made my own. if you go to any parts store and find the right fittings to screw into the intake and hydravac you can simply slide 3/8 fuel line on it clamp it and off ya go
| | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | Also I've seen check valves on each line after it exits the intake manifold. What kind do i need? | | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | those are on newer model trucks arent they ? like the ones on the brake booster? if it is i duno the part number off hand but ill get you the # tomarrow
| | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | Plastic or "Synflex" air brake hose would probably work. I is available at any truck parts house that carries stuff for air brakes. i also like this idea... with a heat gun you could "mold" the line to take any shape to contour and be out of the way for a custom look, im gonna have to experiment, thanks for the idea crenwelge!!!
| | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | stoveboltkid, i got the checkvalve part number you were talking about, Advance part number (sku) 80190 Power brake booster check valve | | |
