4 members (Patina 54, sron48, Otto Skorzeny, FAST55), 114 guests, and 2 robots.
Topics128,034
Posts1,055,440
Members48,422
#537070 05/12/2009 11:03 PM
Can anybody recommend where I can get a replacement radiator for a 61 apache 235, either online or in the temecula,ca area (lower riverside county)?
61cheevy #537085 05/12/2009 11:43 PM
The Truck and Car Shop in Orange Ca. They havea 3 row OEM style. I got mine from them and never had a proglen yet.
http://truckandcarshop.com/
US Radiator is another great place.
http://www.usradiator.com/default.htm
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #537736 05/14/2009 8:02 PM
Classic Radiators is building an aluminum application. Reason I know is mine is the model for the prototype!
Nomad02 #538511 05/17/2009 8:50 AM
If you're worried about being stuck in traffic or driving on really hot days and want some extra cooling capacity, the bigger 3/4-1 ton radiator bolts right in. I THINK mine came from US Radiator, but I'm not positive. It's a couple inches taller, a couple inches wider, and 3 rows. It bolts right into your existing core support.
The only problem you'll then have is the factory fan shroud. There were at least three different shrouds for '60-'62... Only one fits the wider radiator, and it came on Automatic trans equipped trucks, or those with the bigger radiator. If you're handy, and don't want an exactly original shroud, you can pretty easily make your own. I've been driving for a couple years in Georgia summers, with no shroud, a 17-inch 7-blade clutch fan, and the V8 that puts the fan a good 8 inches back from the radiator, and it rarely gets warmer than I'd like, unless it's stopped traffic on a real hot day. I expect the fan shroud will all but solve that problem, too.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
