1 members (Samantha),
45
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53683 12/16/2005 2:48 PM | Joined: Jun 2005 Posts: 50 Member | | Member Joined: Jun 2005 Posts: 50 | The timing cover on my 53, 3/4 ton leaks a little oil, and I'd like to replace the gasket. My question is, how's the best way and is thete a "bushing" that has to be replaced also? Where would I pick up these parts? Thanks Oncemore, Happy Holadays to all, and may Santa bring us all more truck parts! Paul
PJP
#53684 12/16/2005 3:00 PM | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 |
50 chevy 3100
#53685 12/16/2005 3:06 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think there is probably a writeup in the Tech Section on this. Removing the timing cover also involves removing the front crankshaft pulley (damper) and the oil pan. If the leak is only from the crankshaft seal, it is possible to change it without removing the timing cover.
Bushing: Sometimes there is a groove worn in the pulley shaft that causes even a new seal to leak. There is a thin sleeve that you can buy, that slips over the outside of the pulley shaft to cover up the groove and provide a good surface for the seal to ride on. | | |
#53686 12/16/2005 8:18 PM | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | The thin sleeve that truckernix is talking about is called a speedi-sleeve. The one I just looked at in our warehouse was made by CR services. On the box it says they make them for shafts up to 8 inches. The ones I've used have worked fine but, I've only used the ones on 2 1/2' or larger shafts. Most come with a flange on them for installation which can be pealed off after you get it where it needs to be. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
