6 members (Gray_Ghost, 78buckshot, 2-Ton, Phak1, TUTS 59, Southerntruck), 75 guests, and 4 robots.
Topics128,151
Posts1,057,001
Members48,460
Apprentice
Apprentice
I have a 1949 3100, does anyone know the diameter of the center pin in the rear spring pack? I am referring to the pin that locates the axle in the spring pad that is welded to the axle tube.
1949 5 Window 3100
i believe it is 1/4 diameter ,no bigger than 5/16 .you should be able to see the top of the stud on the top of the spring pack .
"Spring center bolt"
Not sure what size it is on the small trucks though, guessing 5/16", or possibly 3/8".
Grigg
Apprentice
Apprentice
For all of you holding your breath... it's 0.500"
1949 5 Window 3100
The 1/2" diameter is just the bolt head right?
The actual bolt will be somewhat smaller, 3/8" or 5/16" I'm still guessing.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
