1 members (sron48),
75
Mod | | | Forums66 Topics128,169 Posts1,057,043 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | I have a 1949 3100, does anyone know the diameter of the center pin in the rear spring pack? I am referring to the pin that locates the axle in the spring pad that is welded to the axle tube.
1949 5 Window 3100
| | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | i believe it is 1/4 diameter ,no bigger than 5/16 .you should be able to see the top of the stud on the top of the spring pack . | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | "Spring center bolt" Not sure what size it is on the small trucks though, guessing 5/16", or possibly 3/8".
Grigg | | | | | Joined: Sep 2007 Posts: 31 Apprentice | | Apprentice Joined: Sep 2007 Posts: 31 | For all of you holding your breath... it's 0.500"
1949 5 Window 3100
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The 1/2" diameter is just the bolt head right? The actual bolt will be somewhat smaller, 3/8" or 5/16" I'm still guessing.
Grigg | | |
