2 members (Gray_Ghost, BC59),
173
Mod | | | Forums66 Topics128,079 Posts1,056,058 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | New latches are different from old latches..looks like they'y need to be cut to work. 55-2nd series. old and new door latches Thanks, Keith
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you have an early truck that got left over 1st series bits, the shiney one in your pic is the correct TF latch, the dirty one looks like AD pic of my 58, original, not replacement pic of original strikerBill
| | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Could be red..The new ones won't work..oddly the first series and second series list the same striker plates so it should have worked anyway..
I could make it look like the otherone easily..just one good cut with a cutoff tool..just a mystery why.
Thanks Bill
Keith
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | don't know who you're gettin parts from, but the 55.2-59 striker is not the same as the 52-55.1 .... some places don't specify with 55's, but parts should be listed like "52-55" and "55-59" - and the latch 52-55 - 55-59 .... close, but no cigar  with a 55 2nd you should always check against the 56 listings, not just depend on "55" - same problem with 47 1st and 2nd series Bill | | | | | Joined: Jan 2007 Posts: 615 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 615 | Right I often google 56 not 55..
I looked at the LMC Catalog and the 52-55 striker and 55-59 have the same p/n..I'll double check.
If they had a different striker I'd try that as a solution..otherwise I'll have to alter these. I need to stare at this a few hours
Keith
