5 members (Gdads51, 55shaker, Otto Skorzeny, Joe H, 1 invisible), 116 guests, and 5 robots.
Topics128,075
Posts1,056,003
Members48,433
New latches are different from old latches..looks like they'y need to be cut to work. 55-2nd series.
old and new door latches
Keith
maybe you have an early truck that got left over 1st series bits, the shiney one in your pic is the correct TF latch, the dirty one looks like AD ohwell
pic of my 58, original, not replacement
pic of original striker
Could be red..The new ones won't work..oddly the first series and second series list the same striker plates so it should have worked anyway..
I could make it look like the otherone easily..just one good cut with a cutoff tool..just a mystery why.
Thanks Bill
Keith
don't know who you're gettin parts from, but the 55.2-59 striker is not the same as the 52-55.1 .... some places don't specify with 55's, but parts should be listed like "52-55" and "55-59" - and the latch 52-55 - 55-59 .... close, but no cigar wink
with a 55 2nd you should always check against the 56 listings, not just depend on "55" - same problem with 47 1st and 2nd series
Right I often google 56 not 55..
I looked at the LMC Catalog and the 52-55 striker and 55-59 have the same p/n..I'll double check.
If they had a different striker I'd try that as a solution..otherwise I'll have to alter these. I need to stare at this a few hours
Keith
