1 members (Otto Skorzeny),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,856 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | I have a 1952 3600 3/4 ton truck, and i have oil leaking from the differential pinion seal. Does any one know where i can get one of these seals? I shall also be re-newing the grease seals on the hubs. But looking thru the 'classic parts' catalog i can't seem to find the diff seal. Can anyone help please. I live in the UK and could do with a little help with this one please. Thanks Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They are available from any parts store here in the States. I can get the Carquest part numbers & check to see if Carquest will send them to you. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i got mine (54 3600) through my local auto parts store. $19. i dont know if this will help you much but it was an ATI (auto value) store and the part # was 411330n.
have you got the pinion nut off? if not, have fun. if you do, you can use a micrometer to measure the od and id. that will help the auto store folks get you a seal that will work.
there is also a piece of felt rope stuffed in front of the seal. mine was in good shape and did not need replacing but if your's needs to be replaced that was a part i could not find. you might be able to use water pump packing.
a speedy sleeve may be needed as well if the pinion shaft has been worn by the old seal. | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | wrenchbender, that would be great if you could see if they would send to the uk. Tim | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | Monkey wrench, yes the pinion shaft has been worn by the seal. Whats a Speedy Sleeve, and where can i get one. Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The part number for the pinion seal is 411330N. The felt is 5M88. The sleeve is 99259. The wheel seals are #2081. These are the National brand. The pinion seal was used on most 3/4-1 tons up to 1972. The wheel seals were used clear up into the 90's. Did you check a local parts store? It seems there would be a lot of Chevy trucks in that area. Our parts stores have parts for europe & asian vehicles. The sleeve is expensive for what it is but cheap for what it does. Let us know if you can't & i'll see what it takes to send them. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | A speedi-sleeve is a stainless steel sleeve about .005" thick that fits snugly over the yoke shaft. It provides a new surface for the seal. NAPA has these parts and I think CarQuest has them as a set. | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | Thanks guys. I will see what i can find over here, and if i have no luck i will be in touch. Chevy dealers in the uk are very few. Regards Tim | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | Can't seem to get hold of a pinion seal and speedy sleeve here in the uk. Can you possibly help? Regards Tim | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | E-mail me an address & i'll mail some to you. [email protected] They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2008 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 53 | Thanks !!! I have sent you e-mail
Regards Tim | | |
