2 members (klhansen, 2-Ton), 85 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#535569 05/07/2009 6:48 AM
I cant get it to start driving me insane! I have good spark and I'm getting fuel. Checked base timing I think it's good but all I can get is a backfire out the carb am I 180 out of time help!
Sounds like it. Turn the engine over to where the the timing marks line up and pull the distr cap and see if your one #1.
Is this a fresh rebuild? did you replace the plug wires? Adjust the valves?
Larry
I don't own a vehicle that isn't old enough to drink.
Pull the valve cover and watch the valves move as you roll the engine over clockwise from the front. Get the #6 exhaust valve closing and the intake opening. This is known as "overlap", indicating that the #6 piston is at the top of the exhaust stroke. Now, look at the distributor rotor, and it should be pointing to the #1 cylinder plug wire. If not, rewire the distributor using the cap tower the rotor is pointing to as #1. The firing order, going clockwise, is 1-5-3-6-2-4. Button everything up and fire it up!
