| | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | So I am running a 56 235 with fenton dual intake and split exhaust. Just put 2 of langdons cater webers on and don't know if I need one or should even worry about it. Any thoughts
Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 |
Brian,
If you have an original-style fuel pump (3-5 psi) you do not need a fuel pressure regulator with the Carter-Webers.
Tim | | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Tim, Thanks. I like when it is that easy.
Brian
