| | | Forums66 Topics128,115 Posts1,056,288 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 33 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 33 | I recapped this radio, it was DOA when I got it after recap I still do not have the tubes to light and the vibrator is not buzzing either. I can hear the transformer hum. What would be the safe approach next check the primary ? I rebuilt a Zenith cabinet radio with great success but this one has me stumped. [email protected]
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I ran into to one like this the other day. With the vibrator out, it was drawing plenty of current and there wasn't enough voltage to light the tubes. I clipped the heavy transformer lead leaving everything else attached and the voltage recovered with the tubes lighting up. The transformer has a capacitor inside the can and the can is filled with pitch. In this situation the cure is to replace the transformer with another one from a parts radio. | | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | Also try unbolting [free from gound] your spark plate. How many amps does it draw? should not be more than 6 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | One of our members has managed to open the bottom of one of these transformers and replace the shorted capacitor. I didn't know that this was possible. I have previously experienced a tar like substance leaking out of a shorted transformer and I assumed that they were potted. As it turns out, I don't think they are filled with tar. I think the windings are probably covered but the capacitor is accessible. | | |
